Monday, May 31, 2010
selective laser sintering part 5: the laser
Hi folks,
Just a quick post, since it's been a little bit since I made one. My thesis has been keeping me busy these days, which is good since there's been a lot of waiting for things to come in the mail. I ended up settling on a 1000mw 808nm laser diode for the first tests, and ordered some wide-spectrum glasses (600-1100nm, OD4) just incase I need to try a few different diodes.
I built a current-limited variable voltage supply using a reference design in the LM317 datasheet this past weekend, and added some large capacitors to try and filter out any large bumps. The laser diode didn't come with a datasheet, but the ebay seller listed it as running at approximately 2.2V at 1.2 amps. The supply is limited to 1.2 amps, but so far very slowly adjusting the voltage up (with a 10-turn pot), I'm only at ~1 amp at 2.5 volts, and that is about as far as I dare turn it up just yet.
There hasn't been much tinker time with the laser yet, but I did take it to some failed prints made with black ABS. The laser has no trouble melting the black ABS plastic from makerbot, or even cutting it and boring holes in it, depending on the distance. Using a print that's only a single layer thick, the laser seemed to be able to cut through fairly quickly, but also if the focus was such that a small area about 0.5 - 1mm wide was illuminated (instead of a point), it melted the layer rather quickly -- I think this is going to work just fine.
Now, to find some ABS plastic in powder form. The laser didn't heat or cut white polystyrene, so I think colour is still definitely going to be an issue here -- particularly in finding a black thermoplastic powder. I'll have to try some tests with the powder coatings that I have from earlier as well, although our tests with a 20W CO2 laser weren't encouraging, and the end result was partially fused but very, very brittle. This kind of makes sense, since powder coatings are meant to be very thin coatings, and are also meant to cure over 6-12 minutes at relatively high temperatures. I'm eager to try Vik's suggestion of a dark coloured sugar, just out of curiosity, to see what that might be like.
I have also decided to replace the SLS powder test rig that I described in previous posts with a much more full sized model, and I've been working on building this in my spare time over the past few weeks. More on this soon, hopefully. :)
thanks for reading,
peter
Hey,
This looks pretty cool so far.
Have you thought about using toner for printers for the powder?
I'm not sure exactly what it is mode of, but IIRC its mainly plastic, and is melted to the paper. So, might be worth a look into.
-Brandon
-Brandon
Hey,
Thanks for the comment. A lot of folks have suggested this before :) , and we tried it with the powder coatings. Unfortunately it seems to be as brittle as the powder coatings. I think the mixture is about half polymer, half carbon black (for toner), and depending on the powder coating its about half polymer and half other things like pigments and curing agents (if I remember correctly).
My thoughts are that if we go the toner/powder coating way we might either (1) need a special mixture (that's almost entirely the polymer), (2) need to try different heat settings -- maybe if you just go a little slower and for longer you can get something less brittle, or (3) potentially 'cure' the part for 5-10 minutes in a toaster oven afterwards. (But if there's nothing for the part to cling to but itself, it might just melt).
There are lots of experiments to do and potential avenues of research on the materials side. I'd also just really like to come up with an easy to create rig that will grind up old prints and make me ABS thermoplastic powder the consistency of flour, it seems to melt so beautifully with the laser...
Alternatively, it might be time to research plastic manufactuerers and send out another batch of e-mails asking about thermoplastic in powder form.
You shoul try a pre-heated part-build. the laser beam just give a little energy to melt the powder. The powder must be almost melted... SLS machines works like that). A white powder could work with a less powerfull laser instead of black power at room temperature. Well... all of this is kind of obvious, but here is my 2 cents =]
Your prints are brittle because of air quenching. SLS machines need to ramp up 2-3 degrees below the melting point of the material. When the build is done the build envelope slowly ramps down in temp if your parts cool too fast it is called air quenching and it gives you brittle unusable parts.
Nice work, congrats on the progress. Just wanted to point out that you may want to be careful when working with the toner. I've heard that, due to the specific size range and/or shape of the particles it's known to be a, decently, significant carcinogen. Not sure how true that is, but something to be wary of.
Hi Peter,
... i'm testing with SLS and 5Watt-diodes and found a supplyer of different powdered plastics which hints me to mix white powder with dark pigments - i have carbon black, ceramic red and blue, some dark green and some thermoplastic pigments too.
Another area is melting coloured glass-powder or black stone-microspheres, what's working with 2-4Watts really good, but not with 1 Watt ...
Viktor
Viktor
Hi Viktor,
That's really encouraging, would you like to collaborate? I had thought of mixing some fine carbon black with a lighter-coloured thermoplastic powder to see if warming the black powder might conduct sufficient heat to melt the surrounding plastic -- but I wasn't able to easily come across any thermoplastic powder to test this with. I would really love to hear where you've found a supplier.
I'm also currently working on putting together a test rig for everything, mostly in the form of an in expensive, mostly laser-cuttable rig that takes the form of a small SLS machine with separate build and feed tables/chambers. I have an engineering model made out of laser cut hardboard that I put together the other day so I can iron out the bugs.
you can e-mail me at jansenpa at mcmaster dot ca , if you would like.
thanks
peter
thanks
peter
Hi Peter,
the plastic supplyer (Color-Plastic) is in my town and distributes plastic-granules for other manufacturers, so dont have a normal shop ... but i have a good contact with the application laboratory ;)
My first test were with icing shugar and carbon black - when heating to much, the carbon black evaporates and you'll receive transparent shugar-trays with some grey inclusions, so better try with lower powers.
I'll ping you ...
Viktor
I'll ping you ...
Viktor
Hi
Great SLS rig you have. Working on the same thing as you. by the way have u thought of using a laser collimator with your laser
Hi. Interesting work, but can't help feeling that you might be getting bogged down in the implementation details (XY tables, etc) rather than focusing on the materials and the sintering process itself. I recommend looking at commercial sls systems and trying to find out what wavelengths/powers/materials they're using. Read some marketing datasheets for a rough overview, then dig up some patents. See if you can get hold of some of their raw material (probably dfficult if you're not already their customer) or printed samples (extremely easy if you pretend you're interested in buying their hardware!). Any friends in chemistry who could analyse its composition for you? Asking a manufacturer for the MSDS for their raw powder may also be useful (I'm interested in your machine, but our Health and Safety guy is concerned about the polymer powder. Could you email him the MSDS?).
Finally, have you tried a kitchen blender for powdering ABS? Will it blend? ;-)
Hello :-)
Could you please tell me what was the Ebay seller and product? How much did it cost?
Would this laser work?
http://cgi.ebay.com/808nm-1000mw-1W-burning-IR-laser-diode-USA-3-day-ship-/270629469408?pt=LH_DefaultDomain_0&hash=item3f02c5fce0
Do you think your laser could burn black paint for "PCB laser etching"?
http://blog.arcol.hu/?p=1501&cpage=1#comment-19184
Hi Casainho,
I used a very similar laser to the one you found, although I think the one I found was a tiny bit cheaper -- around US$20 -- from someone in the US. It's a 1000mw 808nm 9mm dia (I think) diode, and I also purchased a $10 case/heatsink/glass focusing lens combination from an ebay seller somewhere in China.
Intuitively, if it can cut through ~0.3-0.5mm ABS thermoplastic, it might be able to vaporize a thin layer of paint with the proper setup. Give it a try, and let us know! :)
I've been looking for glass-powder sintering processes or if anyone did it with 3d printers and came across this... I own a stained glass store and wonder if any of our fusible glass powders (Bullseye or Uroboros) would fit your needs? The color range is huge, and it's all compatible with a COE of 90. Full fuse at 1450, Tack (sintering) around 1350, anneals at 930-960 F). Your parts might not survive unless you anneal them in a kiln afterwards, too, but it's maybe a possibility? Contact me if you want.. (info@stainedglassofmckinney.com)
I should have mentioned... there are also copper, silver, and bronze clays as well as a glass clay you might be able to build with. All need to be fired after (1250-1600 F depending on material), and all shrink around 15-30%, but perhaps that can be accommodated? You wouldn't need a heated print-head, but the viscosity would be important. A heated bed would probably help, but since drying time is long, you may want a few plates to build on or you'd tie up your machine. The firing part would knock a lot of people out for utility, but then again, you can rent kiln time at any ceramic or glass store, and lots of people have their own kilns for metal work, ceramics, and glass fusing/blowing.
this maybe a stupid idea or a genius idea, but to get abs powder use pellets and espresso coffee grinder.
This would give you particle control on the high end grinders
