This blog is one of those for people building or using a RepRap self-replicating rapid-prototyping machine to log their comments, experiences, and suggestions. The RepRap homepage is at http://reprap.org.
This is a quick extruder made from a short section of 5mm brass tube, 8mm PTFE rod with a central 3.2mm hole for the filament and an experimental PTFE nozzle. The PTFE is drilled about 8mm in to 5mm diameter, and the tube is push-fit into the PTFE. The nozzle is made from 10mm PTFE rod, drilled almost to the end with a 5mm diameter. Part of the outside is shaped down to 8mm (to fit a large washer for support) and tapered a bit. The final breakthrough was done with a .35mm hand drill where the PTFE is about 2mm thick.
The heater is made from a couple of layers of kraken tape and some (partly) insulated nichrome wire reclaimed from a previous nozzle.
Warming this barrel up, the tape didn't appear to be affected, so I fed some ABS down. it seems to melt fine, filling the 5mm brass easily, but I hadn't bolted it down properly to hold the PTFE together, and I pushed the nozzle off before it came out the 0.35 hole.
It seems to be unaffected. The covering you can see on the nichrome is the original insulation: it seems to decompose and can easily be scraped off with fingers, but even where the nichrome is just bare wire the kraken tape is unaffected. This isn't a long term test, but it's promising.
This extruder uses a brass tube, and a PTFE nozzle and insulator as above, but uses a different heater. Two wirewound resistors are placed inside M8 coupling nuts. The nuts are then held together in a vice and a 5mm hole is drilled between them. The two coupling nuts can be placed around the brass tube (or even a welding tip) and held together with tape. you can also pop a thermistor between the tape and the nuts for temp monitoring.
To provide pressure to the PTFE tube joints, a large m8 washer is placed over the nozzle (10mm PTFE rod turned town to 8mm) and bolted to the existing BfB extruder drive (using the enhanced coach bolt drive).
This warms up fine to 220C and extrudes with some force. This PTFE nozzle has a 0.6mm hole, about 0.5mm thick PTFE (thin enough to see light through) but is still able to contain reasonably high hand forces. It extrudes, slowly, but immediately expands to a much larger extrusion.
Eventually I decided to re-build a more traditional extruder. A couple of taps with a hammer broke up the fire cement and allowed me to reclaim the nichrome, m6 BfB barrel and nozzle.
3ohm nichrome heater directly around the nozzle, and 4ohm above. PTFE screwed to nozzle and also secured using bolts and washer. Washer heat isolated using a turned PTFE washer - also holds the m6 barrel nicely in the m8 washer. kraken tape insulating the heater. Coach bolt hack on a BfB lasercut extruder drive, standard GM3 DC motor/gearbox. Standard BfB aluminium nozzle.
There has been plenty of talk in the forums over the need for a 3d scanner. One major method that has been used is to build a turntable to rest you object on. Then with simply a webcam, laser and wineglass you can rotate the object slowly and get a full scan of it.
Well, in the space of 3 hours, two seperate designs for turntables have been posted online. Myself and Simon Kirkyby have both designed turntables that work on essentually the same principal, but taking some different routes in the actual design. I was going to be posting about my own design but simon's appeared as well so I though I'd put them both up here to make sure everyone knows about them both and can use different ideas from both. I'm pretty sure there is some wierd 1000 monkey thing going on though, because Simon and I live within 10km of each other and have met together on the reprap project before.
Both designs have the following advantages: 1. Every part is less than 10cm by 10cm. Meaning they can be printed in a cupcake printer. 2. Both are based on a simple dc motor 3. Both can be pretty easily run based on a DC driver circuit and a very simple arduino program
So, onto the designs. Apologies for the quality of my pictures.
The design needs some improvement, It was designed for printing, but when it come to milling that stand is very wasteful (thanks to forrest for pointing this out). But can probably be improved, I personally am a little bit dodgy when it comes to the gears themselves, so someone might want to have a look at them before printing. The Stl files can be found attached to this post I made in the forums yesterday. While a more detailed look at the design can be found on the perth reprap blog at Free As In Steins
The second design was done by Simon Kirkby. His includes a spot to place your camera and laser. It uses a different design and isn't quite as angular as mine. His looks to possibly use less material, but not be millable.
Lately I got this crazy idea to print wings for RC planes with my MakerBot. It actually turned out pretty darn well. Big thanks to the Thingiverse community for helping me out with the models and such. If anyone wants to try out some sample wings, or has a wing model they'd like to see 3D printed, get ahold of me!
I am follow the reprap blogs for a while and I am experimenting for a while. But this is the first time I post something myself.
I am building a darwin design with off-the-shelf parts as much as possible. See pictures.
It is not complete yet. I have to order now the motors and the electronic parts and the extrusion head at maker bot. The main purpuse for this darwin design is to build my own (two different sorts of )print heads and experimentating with them.
I thought I'd take a moment, while folks are thinking about a design for the next generation machine, to post the design that my father and I have been working on. My Dad is an electrical/mechanical engineer with about 25 years of designing and building all sorts of industrial CNC machines under his belt, and I'm a PhD student with a mixed background in physics and artificial intelligence, working in neural computation. Together, we figured we could come up with something interesting. :) Our goal was (and is) to build something inexpensive, with off-the-shelf or scrounged parts as much as possible.
We initially set out to make a little CNC mill that we could attach a dremel to, and so we constructed a 3-axis CNC mill with a stationary table and a moving gantry. We made two iterations -- the first using inexpensive (and just bad) lead screws made with ready rod and nuts from Home Depot, and the second with belts. Our lead-screw version was overly precise, fairly slow to move, and had a lot of issues with the cheap lead screws binding. The current version, using a belt drive for the X and Y axes, runs quite well -- it's both speedy, and probably as precise as it will need to be for something that extrudes a liquid. :)
The Z axis does use a lead screw. We tried a few different options before settling on probably the most unlikely (and, hillarious) choice. My dad found some car jack's on sale for about $10, with heavy duty lead screws in them. He figured for $10 you couldn't go wrong. The nut on this axis does normally have quite a bit of backlash, but since it's mounted vertically the weight of the tool pretty much negates that, and you have a pretty good lead screw for not too much. This one is definitely over precise (I think around 4000 steps/inch), but it actually runs quite fast if you're just zipping up half a millimeter to your next extrusion level.
The extruder has a typical extruder heater assembly made from parts from the RRRF, with a simple pinch-wheel extruder made from little bits we had laying around. The plastic can /POUR/ out of this thing, but we would like to replace the toothed gear to something with a little more bite, because it slips at certain speeds.
The controller is very simple -- it's essentially a dsPIC33FJ256MC710 connected to a few darlington arrays (one for each axis), a few power supplies for the various voltages required by the steppers (4V and 6V), logic (3.3v), and heater (12V, but variable -- we usually run it a little sweet, since the darlington on the PWM board seems to drop the voltage by about 0.5v). The dsPIC is definitely overkill for this situation (256k of program space, 30k RAM, ~100 I/O pins, and various peripherals -- SPI, I2C, ADC, UART, etc.), but it's what I have experience with, and had laying about. The dsPIC controls all the stepping patterns, temperatures, etc., and has a parallel port interface (for interfacing to various pieces of milling software). We've just recently ordered a full set of Generation 3 electronics from Makerbot so that we can easily interface with standard reprap software, but if I have time some day I'd like to consider porting the software to the dsPIC.
All in all, we figure that we have invested maybe $100 in the machine (aside from the Gen3 electronics we just ordered), and the rest was from bits laying around. The plastic was salvaged, the steppers were both from old printers and from a local electronics store (we use two different kinds), the belts, cogs, and table were from old plotters, the darlington arrays were from old printers, and so on. We did pick up some drawer slides from Lowes that had ball bearings in them, and run very smoothly for the length of the machine.
So far we've just printed out a couple of boxes -- essentially a few simple patterns that I could easily express in some dsPIC code. We were awe struck when it actually started printing things out, and have watched both times in amazement as it creates things.
I am new to RepRap and want to give a heart felt thanks to everyone who has contributed to where we are today. I recently built a bootstrapped Darwin by making all the printed parts out of MDF and poplar. I had my first successful print last week and am looking forward to making my machine a true RepRap in the near future. I also look forward to being a contributing member of the RepRap community. You can read more about my progress at http://blog.onshoulders.org.
Now that you know my background I would like to shed light on what I feel is a fundamental flaw in the Darwin mechanical design. Please understand that I think the Darwin design is top notch. Still, everything has room for improvement.
Before I built my extruder V2.0 I got stuck with an RRRF that wasn’t selling stepper motor driver boards and no Makerbot Industries. Thus, I attempted to mill the PCB with my working Cartesian robot and a Dremel. Let me throw up a picture and then describe what happened.
As you can see, I got close. However, there are areas where the bit dug through the board. After a weekend of trial and error I narrowed the problem down to a flaw in design. I really should render a 3d animation to make this clear but let’s give words a try first. Imagine with me that you have a Dremel flex shaft mounted to the Darwin X carriage. Imagine that the bit is milling the PCB, moving in the –Y direction, keeping X and Z constant. Milling requires force on the board, which means the board applies force to the bit, in turn. The force on the bit is in the opposite direction of the motion of the bit. Put simply, I have found that this force is enough to twist the X axis guide rods. When the guide rods twist the X carriage rotates about the X vector and pushes the bit into the board.
How to fix? My solution (I have not tried this) is to redesign the X carriage in order to mount the Dremel flex shaft between the guide rods and maybe use heavier rods. Vik pointed out that the BitsFromBytes design has four guide rods. This might also work.
I feel that future designs (Darwin revisions and Mendel) should consider all tool head types, both additive and subtractive. I realize progress is being made with additive board construction, but we still need subtractive! Options are always good, right? Thanks for listening and I look forward to contributing in the future.
Still needs some work as there are some issues with the design.
1. The supports for the X axis do not have enough clearance from the frame. 2. No primary carriage ( need to investigate tool changer) 3. Not sure to use pully/belt drives or running threads.
I have tried to keep the number of unique parts to a minimum, however there are still some systems that need to be added.
Anyway I need some sleep , If this post is incoherent ramblings please feel safe to ignore it.
Phew , what a day. I hope some other reprappers get some inspiration from this design.
This machine still needs it's leadscrews, motor mounts, and build table, but all three axes are smooth as silk, and don't appear to have much play.
In what I hope is one design soon to be followed by many, the only tools needed to construct this are a cutting implement (we used an angle grinder, but a hacksaw would have worked just as well) and a wrench. I'm working to replace the drawer rails with a linear bearing design using skate bearings.
I've got a complete set of electronics and motors for this machine already, and hope to have it functional in time for Penguicon (May 1 - 3rd) to show it off along side this year's Hack of Honor: The CandyFab. Pictures to come as that happens.
You may be able to see in the pictures that we've already mounted some of my $1, no-tools pillow block bearings in preparation for mounting the lead screws. We're using 5/16th inch allthread rod for leadscrews. It's fairly rough stuff, so I'll be running over it at least once with a cheap ($5) die from the local hardware store. My limited testing, and advice from others suggests that should be enough to produce a very functional lead screw.
Feel free to ask questions, post comments, and make suggestions for improvements. There are already changes I would like to make to this machine, but I felt it was important to get pictures online fast.
One last factoid, it's build area is about 12 inches square, with about 3 or 4 inches of usable Z travel. By moving a couple of the beams around, it should be easy to increase the usable Z travel to > 6 inches. These limitations are most likely the result of poorly chosen lengths of beam used, as the drawer rails have 22 inches of travel. What can I say, it's a prototype.
Last July, I got stopped with problems with the Z-Axis. I put the project on the shelf and resumed my normal life. Last week I had an idea hit me how to solve the problem. I will be testing my idea later this week or early next week. If it works well, I will submit the drawings and STL files to the community. If it doesn't work, I'll try-try again.
Basically, the problem that I had was bent threaded rods. This new design will allow the 8mm rod to move within a 10mm hole. The only problem with the design is the thickness of the nut is a variable. That problem can be easily solved by sanding the cover or just choosing a different trapped nut.
The past month has been a flurry of activity over here at MakerBot. Since we launched the prototype design we spend about 2 weeks working day and night to perfect the CupCake CNC design. Then we had to transition to production, as well as document the whole thing in its entirety. That whole process is very involved, and to be honest a bit boring. Creating detailed parts lists down to the last nut and bolt, writing docs, re-writing docs, taking pictures, re-taking pictures to get a better shot and all that stuff really pales in comparison to actually sitting down and printing stuff out.
Luckily we've managed to find time to chill out and print some stuff under the guise of 'fine tuning the print parameters' and 'debugging the code'. The happy folks over at Thingiverse have been very productive lately and have been cranking out cool designs for us (and you!) to print. These are some gears that we printed. We've also been working on a secret model that we're printing. We'll be blowing your minds soon with that, don't worry. Anyway, I'll stop blabbing for now. Here are the gears!
These gears were made by by a Blender script that generates gears. You can check out some of its models in Thingiverse. This awesome script allows you to generate all sorts of gears, including gear racks and such. really rad! We printed a few of them and they mesh very nicely, and the ABS they are printed on is very strong. I like them alot.
Interesting side note: once you have solid 3D positioning hardware and a solid extruder, then its all about the software. If you look closely these gears are both pretty much exactly the same. They even have the same defects, which means that if we improve the software to not cause those defects then the printing quality is improved. Ya gotta love being able to download improved software to improve a physical device.
Oh, and if you're wondering: the CupCake CNC kit will be shipping this Wednesday the 15th. We have 5 presale kits left. As a special bonus to people who order the presale, we're including the bonus toolkit with all the tools you need to build it (stuff like solder paste, an avr programmer, hex keys, PSU, plastic, etc, etc.)
My jerry-built extruder is blocked. The coach built drive is still working fine, providing quite a bit of force to the filament - enough to tear big chunks out of it. The extruder is blocked.
This happened before, during hand testing. I've restarted and stopped the nozzle several times, and only twice had a jam. Last time, clearing the 0.6mm nozzle hole with a pin did not restart the flow, so it isn't a nozzle blockage. Providing *excessive* force suddenly cleared the blockage and restarted the flow, where it went back to normal.
There is one factor that was the same between blockages.
Both times, immediately before, the filament had been left in the nozzle, and the nozzle had been left hot for several minutes, while testing other stuff. Then the nozzle was turned off and cooled down (end of testing). The next day, the nozzle was blocked. On other tests, either the filament was withdrawn while hot, removing the bulk of the plastic, or after extrusion the heater was switched off immediately. Restarting the next day was fine.
I *think* what happens is that the heat travels up the filament, softening and widening it. Over a couple of minutes or so (if it cools immediately) this isn't a problem. If the heat is applied for several minutes, the filament softens further and further up, pressing against the sides of the channel, causing more and more friction. Because my insulator isn't uniform (there is a .3 mm step near the top, and a hole across (see screwdriver drive) this gives plenty of friction - blocking the filament channel. This is why clearing the nozzle doesn't help.
I'd suggest that if you're not using the extruder, or between days, turn the heat off - or better, withdraw the filament an inch or two while hot. My fully assembled extruder worked well, but last time I was testing the axes and trying the sort out a software bug, and I left the extruder hot for 20mins or so while doing so. The next time, it's solidly blocked - no extra force is shifting it. I'll either have to leave it hot for a half-hour or so to see if it softens enough to shift, or disassemble and drill out the stuck filament.
I went out yesterday and bought a small vice (£4.50) and a reamer like Nophead's (£3.00). I'm planning to use the Afghan Lathe technique to make a new extruder insulator with a larger melt chamber (4-5mm?) and a tapered entrance to see if this helps.
So after a week or so of battling extruder problems, machine instabilities, and firmware issues, I was finally able to print a few objects on my repstrap!
I decided to use the dodecahedron (above) as my test object as it presented a couple challenging hurdles that would really show the capabilities of the machine. These are primarily the ~30˚ overhang on the side of the object as well as the fact that the top few layers are extruded over a void due to the part being hollow. Accomplishing this requires some care for extruder speed, heater temperature, and active cooling as I found. Turning on my extruder fan during the layers spanning the void on the top of the dodecahedron helped greatly. As you can see above, the print turned out pretty good, but I still have some more settings I need to tweak. I probably printed a good 20 objects getting to this point, changing setting a little each time trying to get better results. For now I am pretty happy with the results. I'm posting the settings I used so if anyone has any suggestions on things to change please let me know in the comments!
As always, check out my personal blog for more details.
Cheers to the whole Reprap community for all their help getting me this far!
The photos show the complete set of parts printed in PP, the ones on the left I showed in my last note the ones on the right are the last ones off the machine.
Gradual changes were made to the settings going from left to right. The first two prints were done at 235 and 220DegC, a slight improvement was seen in the reduction in temperature, further reduction did help a little but it made the material hard to extrude, the minimum pratical temperature being around 208-210DegC, layer adhesion was poor at this temperature so this was taken as the raft interface temperature.
I commented last time on the elasticity of the material, it pulls back from the edges on infill given the least opportunity. Note the effect either side of the hole on the top face of the foot. I thought that a reduction in speed would give the filament time to relax a little. The third reasonable looking foot was printed at 8mm/sec the best parts on the right printed at 6mm/sec. (220DegC with a little fan cooling)
I called it a day at this the results are not to bad, not in the same league as ABS but PP is a real proposition for printing.
The parts are incredibly tough and reasonably accurate. Across the width the cross brace is +0.05mm, in Z its +0.7mm, the holes are -0.5 to -0.2mm.
I might try and build a coupler out of polymorph. My solder join is only straightish (a couple of degrees off) because it wasn't held very well while setting. I could also try supergluing a similar reinforcement with the slots - I don't think it will be strong enough on it's own.
And it should be ready to go soon. I tried using the host software to build a 10x10x10 square, but it started moving the Z-axis down, away fron the endstop. I'm not quite sure why yet... I'll try the replicatorG and the g-code to see if it has the same effect.
The M8 bolt in my BfB extruder hasn't been gripping the filament well. I've tried the standard tricks, sharpening the thread, increasing the force (until I cracked the acrylic), but I'm still able to pull the filament out by hand against the thread. While shopping around, I came across some coach bolts with much deeper, sharper threads. Simple replacement of the M8 bolt was difficult - there aren't nuts that fit and it was impossible to attach the existing gear or provide vertical support. I needed a bolt with m8 at one end for the gear and bearings, and coach bolt screw at the other for the filament bite. So I made this:
It's soldered together ( see pictures for more detail of how), but if I had an extruder I could easily have made a coupler, since the joint is in compression.
It seems to fit OK into the BfB assembly, with a little modification of the bearings (one bearing, rearranged nuts to fit). It grips the filament lovely now, and hand-winding the gear drives the filament well. I then attached my rebuilt extruder nozzle.
Lightweight and fast G-Code printing with the Arduino
For once, a post with real text and no images from the RepRap team (Philipp and Marius) in Vienna! Fear not, we'll fall back into our usual picture post at reprap.soup.io soon enough.
This setup has got some weaknesses and this piece of scribbling will outline what these are and give a short heads-up on possible ways to easily work around these.
1) Data loss
Once in a while, we notice irregularities in the printing process. Twice, these irregularities has been serious enough that the extruder head suddenly decided to move down ca. 1 centimeter into the already printed part. Forensic analysis has shown that nothing is wrong with the G-Code file itself. As all coordinates are transferred using absolute positioning, the only explanation left is that we have lost one or more serial bytes. In the two really bad cases, we most probably lost the first digit of a Z axis movement (e.g. instead of "G1 Z15.34", we got "G1 Z5.34"). Using this theory, we probably experience data loss much more often, but we just don't notice missing bytes in most other cases. Since we're printing at 19200 baud, we can rule out any error in the serial protocol sampling (0.2% error I think).
Other causes could be noise, a bug causing a 1-byte overrun of the serial buffer, or a firmware bug causing the serial interrupt to be held back too long.
To get to the bottom of this, we've extended the built-in serial class in Arduino to support detection of data overrun and frame errors and report this back to the host whenever it happens. Time will show what we find.
2) ReplicatorG woes
While being a neat and user friendly piece of software, ReplicatorG has caused us some headache lately. It's hard to say what causes this but while running, ReplicatorG gradually slows down, slowly eating up more and more CPU time. It also appears that memory usage keep piling up, but it's hard to see through the JVM without digging deeper.
On Windows, we haven't managed to make ReplicatorG live for more that ~15-20 minutes before crawling to a halt.
Inheriting the codebase from Arduino (who inherited theirs from Wiring who again took it from Processing) enabled a very rapid development process of ReplicatorG. Unfortunately, the result is code which isn't as clean as one would have wished for. Personally, this has resulted in me not managing to muster enough motivation/courage to really dig into this and try to figure out what's wrong. Unfortunately, the fear of large code bases has also kept me from building up courage to tackle the other java host software : / Maybe I'm just not a GUI person.
Together with Philipp, I decided to quickly toss together a cmd-line alternative. The result so far is something with the codename metahost. This is a cmd-line application written in python using pyserial. It reads G-Code and sends it to the RepRap while giving progress info. In addition it supports warmup/cooldown scripts like ReplicatorG. We might add support from reading machines.xml directly from ReplicatorG in order to collect all machine info in one place.
3) Serial speed
The reprap prints at 19200 baud. This shouldn't actually cause any problems, but we discovered something worth mentioning: The baudrate calculation on the Arduino is a bit suboptimal. Specifically, it doesn't use the U2X bit on the AVR which enables for twice the bitsampling rate. This again causes the 115200 baud mode to be useless due to a 3.5% error. The following code can be used to optimize the baudrate setting: #define BAUD 115200 Serial.begin(BAUD); #include <util/setbaud.h> UBRR0H = UBRRH_VALUE; UBRR0L = UBRRL_VALUE; #if USE_2X UCSR0A |= _BV(U2X0) #else UCSR0A &= ~_BV(U2X0) #endif
We're printing at 115200 baud for now, testing how stable this is in practise.
Inspired by Nophead's observation about short thermal transitions being necessary as well as by a desire to try a different way of heating the extruder, I have made the following extruder which is working well so far.
1. 6.3mm (1/4") thick aluminum L shaped extrusion as heatsink. Total surface area about 15100 square mm (23 square inch). Hole is tapped for 10-32. 2. 10-32 brass nut. This is in the heat flow path between tube and heatsink, so no lockwashers, etc. 3. Tube made by putting a 10-32 thread on a 4.76mm (3/16") OD, 0.71mm (0.028") thickness stainless steel tube. In order to put on thread successfully, put a 3.17 mm (1/8") diameter rod in the tube. 4. TO-220 PNP transistor (P/N NTE-153) with mounting hole drilled and tapped for 10-32 thread. 5. Thermistor holder made from copper sheet. Hole is thru hole for 10-32, not tapped. 6. 10-32 acorn nut, with 0.5 mm hole drilled in the end (done with a PCB carbide drill).
Putting the thread on the tube with a 10-32 tap is tricky, but putting a rod inside the tube to hold it straight helps. The tubing gets so thin that you can see ridges on the inside of the tube pushed up by the teeth of the die.
The PNP transistor has a rating of about 150C. I am taking a chance at running it at 240C for extruding ABS, but it has worked for about 10 hours run time so far without failure. I chose a PNP device so that I could connect the collector to the frame of the unit, since the tab is the collector. Here is a schematic of my drive circuit. I adjusted the pot until there was 1V across the 1 ohm resistor. With a 12V power supply, this means that the transistor is dissipating 11W. One reason that I used the PNP transistor is that it is possible to use the transistor characteristics to measure its temperature. I have not tried this yet, since it would be somewhat complicated, and I wanted to get some extrusion hours under my belt.
It is possible to get power resistors mounted in the TO-220 package. They might be a higher temperature rating and would be less complicated to drive with the standard circuit.
I have not found it necessary to have any more heatsinking than the L bracket (item 1), and I do not have a fan on it.
I have successfully used this with a pinch wheel consisting of a knurled nut.
Here are some pictures of the unit mounted on my repstrap.
The pictures are the first two attempts at repeating the early PP minimug. I managed one decent PP print and following that I never really managed to repeat the results.
There was a little interest in PP as a print material I thought it worth showing it warts and all through the development. They are not pretty but there is definitely potential.
Doing a little more experimentation on the material it seems very similar to PCL in its quality, it warps, it holds its heat and it sags if you get it all wrong. Check out the first print, I could not get this off the PP build board, but large diameter section is very clean, then it runs up the object concentrating the print head in one area and it clearly overheats the material. At the top its has sagged, and lost detail and generally melted into a mess.
The temperature was a steady 235C up through the object. Another observation during the build was the elasticity of the filament when molten, at 16mm/sec any resolution on the internal fill pattern was all but lost.
The second corner bracket was with a cooler raft temperature 220C 12mm/sec. At this temp it was possible to get the object off without damaging the base material. I stuck with the same lower temperature up through the build and the results are a little better but still too hot. The detail of the two holes being distorted. Next I will try a little cooling to control the layer temperature and see if this works the same as it does for PCL .
