Monday, June 23, 2008
Alternative alignment
The Darwin build instructions recommend squaring up the frames by adjusting the corner blocks to get the correct length stubs sticking out, as the excerpt below shows: -
This assumes that the rods are exactly the same length. I think what is actually important is that the gap between the rods is exactly 400mm. To achieve that I made a temporary jig from a couple of diagonal tie brackets and a piece of the 8mm rod and adjusted it so that the outside of the brackets was 400mm. I then used that to space all the rods of the lower frame. I also set the short stubs to 20mm using the first method above. Any variation in rod length then ends up on the the 28mm stub.
Labels:
Comments: Post a Comment
