Thursday, February 14, 2008
Ianus Bearing Mounts
Now I can start on work towards the slides etc for Ianus, here is the assembled bearing mounts ready to mount on trolleys. The idea for these came from http://buildyourcnc.com/ clever but simple, the best ideas always are. We are using Skate bearings (608 ABEC 7) here, M8 x 20mm Machine Screws and M8 Nuts. These screw right into drilled and tapped holes on the trolleys.
Hi!
Im wondering, that you are using for a "bearing nut" just 1 bearing(608), 1 screw (M8 x 20mm) and 1 nut (M8)?
(So 3 pieces in total).
Are you NOT using any washers?
( http://en.wikipedia.org/wiki/Washer_%28mechanical%29 )
I need to try it out anyway, (if the M8 nuts stuck on the bearings and keep it from rolling or not)
Best regards,
Khiraly
Best regards,
Khiraly
