Wednesday, September 19, 2007
Gears are going to be possible
Just got through with my first 7-toothed gear perimeter. The print layer has bad settings for height and flow rate, but it's pretty obvious that the work I put in on improving the positioning system, never mind making a new extruder barrel is paying off. The teeth on the gear all look the same regardless of their location on the gear perimeter. I made them really big so that I could be sure and not fool
A lot of the problems are coming from the routine that I use to generate the perimeter. It does the teeth twice at the same level for each layer. I've got to fix that.
(Read the full story)
nice! looking good forrest.
