Sunday, April 22, 2007
Well Forrest, here's me being stupid..
Anybody notice a systemic logic problem here?
void toggleP12v()
if(P12v == 0)
P12v = 1;
else
P12v = 1;
void toggleP5v()
if(P5v == 0)
P5v = 1;
else
P5v = 1;
void toggleClock()
if(Clock == 0)
Clock = 1;
else
Clock = 1;
Cut and paste can get you! Lol they turn on just fine by the way.
void toggleP12v()
P12v ^= 1;
Less scope for error ;-)
hmm.. did you mean P12v ^= P12v?
I found that I had to represent 2*a as a+a or I got a mulchar error in sdcc, so I went for simple assignments :) Did you oops now too? Maybe its communicable.
Bart, I certainly do make lots of typos so I try to make my code as short as possible. However that was not one of them.
In C ^= means exclusive or and assign so x ^= 1 is short for x = x ^ 1 which just toggles the bottom bit of x.
What is P12v defined as? If it is a macro it may need to parenthesis it. Or perhaps your compiler is broken. To prove to myself I was not going mad I tested it with the Comeau compiler try it out page at http://www.comeaucomputing.com/tryitout .
This is the ultimate arbitor for solving programmer versus the compiler disputes. I defined P12v as a bit field for the test.
struct x {
int y : 1;
} z;
#define P12v z.y
void toggleP12v()
P12v ^= 1;
Thanks for the tip, I didn't recognize the usage. Assuming it works in SDCC, it would have done the trick. I like to code with simple constructs that anyone can understand. As you can see, I need to keep it simple :)
i'm not sure if this version works in C, but i use this in PHP all the time:
flag = !flag;
Zach,
Yes it does work in C but its meaning is slightly different. My example toggles the bottom bit, regardless of the size of the variable. ! will read all the bits and if not zero set the result to 0 else 1. If P12v is a single bit variable then the effect is identical. Depending on the compiler and the instructions set one may be more efficient than the other.
