Thursday, April 12, 2007
Can a shot glass be far behind?
I discovered that the shaft encoder magnet on the x-axis was not glued to the end of the shaft but only stayed there through the magnetic attraction of the encoder magnet to the steel rod. I glued the magnet back on and then ran another raft and square perimeter exercise.
While the resulting 20 layer square perimeter still had a drift, to the +x (right) this time, it was pretty continuous and the + and - x walls to the square perimeter were solid. The square and raft assembly was also rigid.
I looked at it a while and then got to wondering if it was also waterproof.
I poured some water into it and ... it was.
The Tommelise Mk 1 AEM extruder can make waterproof vessels in HDPE.
